Old 09-05-2016, 07:44 PM   #6
78F350
Motorist & Coffee Drinker
78F350's Avatar
Originally Posted by Rok986 View Post
...Will have to change it, but now don't know which hose connects to the resonance flapper valve.
Starting from the vacuum reservoir: Connect to electric change-over valve "J", then to the flapper valve. The Y "I" in the diagram will only be present if you have a Tiptronic.
Also, does anyone know where (E) is located? ...
"E" is located behind the Alternator.
Check out my video in this thread to see "E".
Vacuum Confusion -SOLVED
