Old 09-04-2016, 05:07 AM   #24
Xpit77
Xpit77's Avatar
Originally Posted by BoxsterSteve View Post
Store it if you want, but starting it periodically is a bad idea. The engine needs to get up to operating temperature, and that takes 15-20 minutes of driving. Idling just doesn't cut it.
Do like most and don't run it while in hibernation. Your car will thank you.
Fill the tank, add some fuel stabilizer, pump up the tires and throw a cover on it.
As far as what you have spent, it's all preventative work and setting a maintenance baseline.
Don't fret.
I never fill the tank. Around 1/4 and a non- ethanol fuel with Sta-Bil .In the spring you only have a small amount of old fuel in the system to burn off not a tank full. Tape the exhaust tip or put steel wool in it to keep out the mices. Do not forget to remove it in the spring !Maybe a battery tender too.
99 Boxster sold
88 944S sold
Xpit Formula Four sold
95 Integra Solo I sold
71 Opel GT sold
