Old 09-03-2016, 03:28 PM   #13
Cbonilla
A few closing thoughts
I agree, plastic dip is a non starter
My view is that any refinishing needs to have the wheels taken apart. There is no other way I see to clean up the corrosion. And in my view the wheels, being two-piece, allow water to weep out. Since I live in a freezing climate I don't think it would be smart to trap water between the two wheel parts. And painting them will paint over the screw heads and I don't even do that at home with light switches.
As of now my plan is to disassemble the wheels. I'll start with two of them and re-evaluate.
With the tires still mounted. I will Remove the wheel bolts, separate the centers and use wet dry sandpaper to clean up the corrosion on the rims, leaving the centers as is - I can live with their condition
At the end I will either paint them or simply clear coat them. Does anyone know if they were painted from the factory?
Cbonilla is offline   Reply With Quote
