Old 09-03-2016, 11:17 AM   #7
JFP in PA
The AOS doses not normally hiss. You should be checking the vacuum level (in inches of water) at your oil fill cap. It should be steady at 5 inches, if it is lower, something is leaking, if it is higher, the AOS is shot.
