I had a CDR-24 with the MOST connection to the HD amp. It will require that MOST optical connection.
The amp is a drop in replacement for the HD amp.
It required new wire to be run for the rear deck (4 wires).
I then had to change the harness plug (wires are a color/size match , so it was a matter of splicing, soldering, and shrink wrapping - took about an hour).
Speakers were a drop in replacement.
Total time spent was probably 5 hours - most of that being very careful with the door speaker swaps.
