Thread: White Smoke
Old 09-01-2016, 08:53 PM   #13
rexcramer
1997 Tip, 2018 Macan
rexcramer's Avatar
As others have hinted ,the cause may be benign but they did not explain. Others will do a better job than me -but here is a beginning at an explanation - the flat engine configuration may be the problem. Oil tends to slowly drain & pool to places where it combines with the combustion mixture in the first few revolutions of the engine after starting.In a vertical engine, oil in the upper part of the cylinder bores would drain past the rings, down into the sump. In the flat engine it accumulates in the lower portion of the bores but 'above' the piston rings.There is no gravity drainage part the rings.
The next stage is to find out which cylinder is worst and why.That is another thread.
VW's and Subaru flat engines, with lots of miles, can smoke on start up after sitting for awhile also. Trying to pull the oil cap off while the engine is running is a 'shade tree' mechanic test. A manometer would definitely dial it in for you. How many miles on your engine? Once after a week, most likely a non-issue, depending on mileage. Definitely don't ignore it, if it continues. A compression test and or a leak-down test might also shed some light too.
