Old 09-01-2016, 06:32 PM   #1
DWBOX2000
Sorry I tend to put questions into buckets. Point noted. Will try to oblige.
Ok, the rod end is removed from the carrier. The nut will not go back on. It turns on about
A 1/2 turn and then it stops. The threads look fine and the bolt is straight. No visual reason it should go on. Stump.
Thanks for responding.
DWBOX2000 is online now   Reply With Quote
