Old 09-01-2016, 02:52 PM   #1
Gilles
annoying small leak...
I have a very small oil leak from the valve cover on the 1-3 bank, and it is very annoying nonetheless because it makes a mess after a while.
Can someone recommend a seal type or something to apply on the seam between the valve cover and the head..?
Or the only solution is to remove the exhaust, lock the cams, remove the ignition coils, the cam cover, etc., and apply the proper sealant...?
Thank yo in advance for your comments.
