Thread: Yaewp
Old 07-01-2006, 12:29 PM   #1
bigislandboxster
The older the car gets, and the more it gets driven, the more likely something will go...If you're not a do it your selfer, and you drive your car regularly, it might be a good thing to do. What does the warranty cover? Thats important too...Does it cover the dreaded RMS? I went for piece of mind on my '98, as I knew I did not want to be pulling large sums of cash out of my pocket. In a little over 1 year on a 3 year warranty, it has almost payed for itself.....If you can afford it, it might buy piece of mind. If you don't use it, then at least you're covered....
1998 Guards Red Black/Black 5 sp.
Work done '06 :Replaced bad hose and clamps from reservoir tank
oil change and filter
replaced seals on both cam covers
brakes bled and refilled
Replaced bent rear right lower control arm
Front air dams and 3 underbody panels replaced
Halogen headlamps replaced
bigislandboxster is offline   Reply With Quote
