Old 08-29-2016, 08:20 PM   #3
FauxDiablo
1) Put the car on jack stands.
2) Full tank of gas. Do NOT use "HEAT" if you live in a gasahol state. (10%-20% ethanol)
3) Previous poster said change oil. Nope. Change it AFTER winter storage**
4) Remove or change coolant if you are not sure if it will withstand -20F temps.
5) Remove battery, bring inside, attach a small trickle charger.
I'm in Minnesota, where it actually gets COLDER than most of the populated areas of AK.
**Do you want to run your car all of the next year on oil that's been sitting for 6 months in subzero temps? Or do you want to start the year on fresh oil?
FauxDiablo is offline   Reply With Quote
