Hey Jim, this was all installed in my car when I purchased it so I'll do my best with your questions. The climate control should be a direct install to the lower console as it is a factory location, the cars equipped with factory navigation came that way. What do you mean by time required to install the update? If you mean the navigation unit I would expect that a few hours would be sufficient. I suspect you can get map updates as the interface looks like a Garmin but I'm not certain, you could contact Pioneer to verify. Hope that helps, this is a great way to upgrade a later car with the MOST system, which is a huge pain to interface with.
