Old 08-27-2016, 11:52 AM   #13
MWS
The biggest secret the gentleman failed to mention with the Boxster is....
If you are standing on the driver side where you would normally enter the vehicle, if you walk around (either clockwise or counterclockwise) to the directly opposite side of vehicle, at approximately one meter from the ground you will find (if you look closely enough), a small-ish simi-rectangular "panel" that is normally painted the same color as the car. Upon examination you will find that the tips of your fingers will fit on the underside of this panel, and if you apply (gently!) upwards pressure, you will find the "panel" is attached by some sort of mysterious lever mechanism to a larger section of the car. If you continue to pull upwards, a large section of the car will "pop" open; when it "pops", pull the section toward you and you will notice that the section is hinged (on the right side) to the vehicle. If you continue to pull towards you and allow the section to swing open at least 45 degrees, you will find this will enable a potential passenger access to the vehicle. Section that has been opened can be closed in much the same manner as that of the drivers side access point. This process can be repeated as many times as necessary to allow passenger access. Important note: be sure that section is full closed before driving vehicle, as many terrible accidents have happened while driving with section open, especially if opened at more than 45 degrees.
