Originally Posted by thstone
Batteries.
Most of the cars in Spec Boxster run an Odyssey Extreme battery. They work great and weigh quite a bit less than a standard full size battery.
Well, they work great until they don't. Everything will be fine and then the battery will be dead as a doornail without any warning or hint of running down. This has happened twice - one time at the track and Brad Roberts had to R/R the battery in 5 mins with me suited up in the car so I could make a race.
The last thing that I need is more stress or something else to worry about at the track. So, now I treat the battery as a standard maintenance item and replace it every 12-18 months (around $150).
Tom I have used one of these on in my boxster for a good 5 years. If you are able to keep it plugged in on a modern Ctek when not in use, you should get considerably more life and reliability out them. The Ctek will give you a mini battery reconditioning program while the car sits....then again I don't live in the desert!
