Old 08-25-2016, 06:53 PM   #13
JFP in PA
I also have concerns about an engine with a LT stat, and S cooler in the winter. This may be due to my old school thinking but If oil in sump never gets above 180 how does it boil off the contaminates? Water boils off at 212 deg. Now at 6"WC vac (sump pressure) water boils at approx 195 deg. Is this why our cars have a 195 deg stat stock?
You are overlooking the fact that your oil is always hotter than your coolant, otherwise an oil to coolant cooler would not work. Even in the dead of winter, your oil is hotter than 200F, even with a low temp stat and the larger oil cooler. We have customers running low temp stats and using the cars in zero and sub zero F environs; UOA's show no adverse levels of water our fuel contamination whatsoever.
