Old 08-25-2016, 03:12 PM   #12
p3230
p3230's Avatar
Good suggestions already but to add to that. When you said you dried it out, did you take the floor carpet completely out to dry it? The insulation on the bottom of the floor carpet is a sponge that won't dry out unless you yank it out and hang it for a couple days. The moisture from that carpet might have corroded your immobilizer again. it's real easy to check the immobilizer without removing the seat from the car.
Yes I did I pulled the carpet up I sucked all the water out of the bottom of the car I put the vacuum to the foam also I let it dry for three weeks while I was gone and then I reinstalled the immobilizer and that's when I noticed that all these things were not working. So if anybody has any clue as to what I could do I'm open to suggestions.
Frank
p3230 is offline   Reply With Quote
