Originally Posted by thstone
Batteries.
Most of the cars in Spec Boxster run an Odyssey Extreme battery. They work great and weigh quite a bit less than a standard full size battery.
That's a huge battery for a Spec Box. It weighs over 26lbs, puts weight high up in a bad spot. Most guys in TX & CO run a DEKA ETX14 or ETX12 which can be bought for $60 and weigh 12 or 10lbs respectively.
Do yourself a favor and take this opportunity to save 16lbs of weight and some cash.
Edit: Pull the cutoff switch when you park the car and you never have to worry about a dead battery.
