Good suggestions already but to add to that. When you said you dried it out, did you take the floor carpet completely out to dry it? The insulation on the bottom of the floor carpet is a sponge that won't dry out unless you yank it out and hang it for a couple days. The moisture from that carpet might have corroded your immobilizer again. it's real easy to check the immobilizer without removing the seat from the car.
Woody
