Old 08-24-2016, 01:13 PM   #17
JFP in PA
I also had a thought since the transmission is out siting on a furniture dolly it might be a good time to top up/replace any manual transmission fluids there might be?
Is there any or is it lifetime grease or oil?
No, there is no "lifetime" product. Buy your gear oil from Porsche only as they use a unique specification product that is made for them, no one else has a direct substitute. You should also plan on servicing the trans every 40-50K miles, like other lubricant service intervals, the gear box oil is too long.
While you have the car apart, it would be a good time to put a 2 1/4 diameter hole in the triangular plate for future trans service without taking anything apart. The plate is soft aluminum, so a decent hole saw (we got ours from Amazon) will make quick work of it. Be sure to hold the plate up under the trans and mark where to put the hole as it is off center a bit.
