Old 08-24-2016, 02:37 AM   #1
dteague
Originally Posted by aczyzewski View Post
I had this problem (driver's side) and was able to pull it apart and fix it. Took about an hour and was a little tedious as I didn't want to break anything. On mine, the vertical slider popped loose from the fins. I was able to pull the unit out, open it up and snap the parts back together. I was impressed with the engineering of the whole thing. Pretty simple really. I have pictures and can elaborate if you decide to try it yourself.
It sounds like you had the same issue as mine. Would love to see the pics and how you did it, so I can fix this one, as well as the one I already replaced.
dteague is offline   Reply With Quote
