			I had this problem (driver's side) and was able to pull it apart and fix it. Took about an hour and was a little tedious as I didn't want to break anything. On mine, the vertical slider popped loose from the fins. I was able to pull the unit out, open it up and snap the parts back together. I was impressed with the engineering of the whole thing. Pretty simple really. I have pictures and can elaborate if you decide to try it yourself.
