In my experience, you want to use cutting oil on smaller threads even if not absolutely required because you'd want to use the lubrication to be able to determine when the tap is cutting and when the tap is bottomed out and about to break, or jamming up with swarf and about to break, which is easy to do because M6 taps aren't very strong.
