Great! I'm not an expert, but I would start with checking fuses (although it sounds like your motor may be working), check to make sure bolts are secure on the push rods and clam shell struts, make sure the "boomerang" is turning when the motor is engaged, and check to make sure the top cables (sort of like a speedo cable) is not twisted up or stripped where it connects to the motor.
