Old 08-20-2016, 05:53 AM   #1
rexcramer
1997 Tip, 2018 Macan
rexcramer's Avatar
I had to restring my drivers door yesterday. I have replaced both sides in the last year. The hardest part (for me) is getting the door card off. The cable and micro switch are short and you need a third hand to disconnect while holding the card. Look at the attached picture.
http://www.carparts.com/details/Porsche/Boxster/Replacement/Window_Regulator/2000/REPP462925.html?TID=gglpla&origin=pla&gclid=CJ-6jp6E0M4CFVYsvQodUAILHQ
It is fairly straight forward job, for a window regulator. Although I have a 97 without an airbag. There are 10mm nuts on top and bottom of each track. And 3 10mm nuts that hold the motor. There are 2 30 torx screws that pinch the glass to the guides. If everything is tight, nothing should be knocking about. I wonder if the window is not in one of the pinch clamps. In any case, sounds like it needs to come back apart.
