Old 08-19-2016, 05:31 PM   #4
hazardc
UPDATE:
I got the frunk open.
At this point I've cleaned the unit out, there was some corrosion, but there wasn't anything too out of the ordinary. The thing passed the "smell test"
EVERYTHING works EXCEPT *NO START* and *FRUNK AND TRUNK ALWAYS LOCKED*
Fob works fine, i can pop the rear still, i can put the top up and down, I reset the memory on the windows after disconnecting and fully charging the battery.
I put the clu back in with the battery disconnected. It's OBVIOUSLY getting power and all functions work except that the car is obviously immobilized and I can't figure out *why* I can lock and unlock the doors just fine with key or keyless
Is there anyone who knows what fuses i should be looking at or where I should be checking for voltage?
Or ANY suggestions on this one? It seems intuitive that this unit is not dead, but the car has been immobilized. Can this be reset with the key?
Looking for
1) any possible procedures to deactivate the immobilizer with the key or whatever
2) fuses that should be checked
3) places voltages should be checked.
THANK YOU in advance.
I do not have a durametric.
hazardc is offline   Reply With Quote
