Old 08-19-2016, 10:04 AM   #2
78F350
Motorist & Coffee Drinker
78F350's Avatar
did you replace your DME as well?
The DME has to be programmed to accept and work with a different immobilizer.
Yes, if you go this route, you have to replace the CLU/immobilizer box, key (fob with transponder), and DME. The set you get all need to be from the same car and the same DME version as your car.
