Old 08-18-2016, 04:15 PM   #3
JFP in PA
Originally Posted by Steve Tinker View Post
No lube required, but there could be air in the system.
When was the hydraulic fluid last replaced? Have you checked the hydraulic brake reservoir where the clutch fluid is fed from?
Actually, there is a special lubricant (Optimoly Olista Longtime 3EP) used on the splines of the transmission input shaft, throw out fork pivot, and where the plunger from the slave contacts the clutch fork.
