Old 06-29-2006, 11:28 AM   #2
KRZTACO
Is your car lowered or stock height?
The reason I ask is that if it's stock, then the shop will be able to align it, no problem...if your lowered than it could be costly to get to an OEM camber. I am lowered 30mm with some coil-overs and the oly way to get my rear negative camber back to OEM limits is to purchase new and very expesive longer custom toe links. I think the set of 4 runs around $1,500 then another alignment and corner balance which brings the grand total of around $2,000 at least. I decided to save the couple grand and apply the dollars saved to additional tire rotations of actually swapping the tire to the other side every 15,000 miles or so.
KRZ
http://x402.putfile.com/2/5800280187-thumb.jpg
Voghtland 30-50mm Coilovers
19x8.5 x 19x10 Forgline rims
Magnaflow Exhaust
KRZTACO is offline   Reply With Quote
