The only difference I know of between the manual & Tip is the freewheel "clutch" pulley fitted to the manual alternator. You can fit or remove the clutch unit and refit it onto a new alternator, but you will need a special tool to remove it from the old main shaft.
2001 MV Agusta F4.
