08-16-2016, 02:53 PM
#32
Originally Posted by paulofto
What, your torque wrench doesn't go to infinity?
It's 150ft-lbs (ok, not too bad - my wrench goes to 250) plus a 180-degree turn (WTF??!!) The bolts are one-time use only, as the end 'twists' to set the hub just right.. and the bolts are 8.50$ each and the only place I could find them was the dealership...
I had to buy a 36" long, 1" format breaker bar with a 18mm triple square bit to get that bolt set right... INSANE. I had to stand on the bar and bounce to set it.
Took a month just to order the tools.
I'm 99.9% sure I'll never need that again. Even the hub bolts on my Rover were 202ft-lbs - no extra twist..
