Old 08-15-2016, 04:57 AM   #7
Jamesp
Beginner
Jamesp's Avatar
Originally Posted by jcslocum View Post
Easy outs suck. They should be called Easy-Break Incredibly Hard Aggravation tools. Drilling them is really hard to do successfully. The best option is drilling around is with a small bit and not break one of them off or get a Dremel with carbide bits and try to dig it out. You better get a Heli coil kit to replace the threads once done.
+1 I won't use easy outs. You cannot drill an easy out as it is as hard as the drill. While it can be ground there is no access to grind it when stuck in a bolt. Use very tiny drill bits to chew away the bolt around it. Slow and careful or they will grab the easy out and break as well. Use a very small cold chisel to tap on the remainder of the easy out after drilling to knock it loose. Get ready for frustration.
2003 S manual
