Old 08-13-2016, 09:02 AM   #1
DWBOX2000
Front Strut help
I put a lowering spring on the left front. I noticed it wasn't any lower. About the same as previously. THought maybe when I do the other side it will be lower. Anyways, I realized I had the bottom washer on the strut flipped the wrong way. No problem, I took off and flipped. The washer seem the same identical to the other. THink it is fine. Anyhow. I was now have the right side lifted. When I went to lower the left, the strut does not seem to be working. The car is not lowering at all when the tire hits the ground. Any suggestions?
Right side went great. Well except. The bolt that holds the brake sensor to the wheel carrier snapped. 6mm X 1. I was going the right direction. I finally got a drill to try and use an easy out and that broke flush with the nut. Any suggestions?
Help please.
DWBOX2000 is offline   Reply With Quote
