Old 08-13-2016, 06:55 AM   #18
78F350
Motorist & Coffee Drinker
78F350's Avatar
SAI Vacuum Hose Replacement
Here's the video I made showing the replacement of the vacuum lines for the secondary air injection system. ***This is for U.S. cars, the SAI was not used in R.O.W.***
The SAI is an emissions system that pumps fresh air into the exhaust for the first minute or two after a cold start. Common DTC codes when there is a vacuum leak in the system are p0410 and p1411. A failure of the SAI system will not damage your car, but a vacuum leak may cause the engine to run lean and lead to other problems.
The video:
https://youtu.be/A731OcZVGTI
