Old 08-11-2016, 02:27 PM   #1
paulofto
2003 S, Arctic Silver, M6
paulofto's Avatar
Originally Posted by MARTHA View Post
Also… I just checked and the stupid dealership put 39 lbs air in both the front and back tires.
The tag located on the door says 30 front and 37 back.
I let out lots of air and settled on 32 front and 37 rear.
Do you think I should drop the front tires down to 30, seems awful low?
Would appreciate any feedback on either issues, the tire pressure and especially the Homelink.
Thanks!
Can't help you with the homelink but tire pressure on these cars is important. For mine, a 986 S, the pressure calls for 29 front & 36 rear. They do heat up quite a bit when driving and the pressure will increase so be careful about over pressurizing the front more than a couple of lbs when cold. I think you will find that handling is best when filled to spec.
