Old 08-11-2016, 12:43 PM   #10
DarkStar
DarkStar's Avatar
Wait until you put the cover back on the case....
The shift fork rods have to fit into all the roller bearing cups in the cover. The shift forks have to be set just right to get it to slip back together and no rollers can fall out of the main end bearing. I found it near impossible at first then easy enough. I had to use grease to hold the rollers in place on the main bearing.
Easy... Use a string to hold 1st and 2nd gear rod towards outside of case. Wiggle and it pops back into place.
Sent from my SM-G925T using Tapatalk
-Josh
2001 Porsche 986 Boxster RS2.7 Bi-Turbo
DarkStar is offline   Reply With Quote
