Old 08-10-2016, 01:33 PM   #14
Tcar
Originally Posted by BhamBox View Post
It has not had the IMSB done, but I've heard that the Tiptronic's don't have this problem as much, and you can cut the oil filter to check for metal shavings before it goes out. I'm still on the fence about getting it replaced.
That is not true, Tips have the same engine with the same issues and the same IMSB.
More expensive to repair too.
Once you have metal shavings in the filter your engine is probably history... an expensive doorstop.
Tcar is offline   Reply With Quote
