Old 08-10-2016, 12:22 PM   #16
drs
Power Steering Pump removal - Boxster 2002
Thanks newBgeek!. Yes I pried the compression ring along with the brass insert out of the reservoir housing. Not good! The prying pretty much wiped out the old ring and also cracked a small piece off the reservoir as well. Lesson learned. The return line is intact, however, so I purchased a new lower reservoir from Pelican which includes the compression ring and will slide the return line into the ring as you described. I'll update when it's back together.
drs is offline   Reply With Quote
