For others that may come across this...
I had the same issue and it turned out to be a relay. Unfortunately I cracked one of the fins on the blower motor when I was removing to troubleshoot. It worked but centrifugal force would cause it to rub as the cracked fin expanded.
Lesson learned: Try the easy things first.
First time I've had a relay fail in any vehicle...
