Old 06-28-2006, 09:22 AM   #2
bigislandboxster
My temp gauge light went off after I had some body work done on the car, dust from the work done must have gotten in the engine compartment, and caused the engine sensor to malfunction. A little cleaner fluid spray and it was good to go....I also had the problem with the temp sensor with the coolant tank when the hose was leaking. I remember mine going off in this instance when the coolant got somewhere a bit below the minimum line, so like PorscheDoc said, you're right at the point where the temp gauge light should be going off.....
1998 Guards Red Black/Black 5 sp.
Work done '06 :Replaced bad hose and clamps from reservoir tank
oil change and filter
replaced seals on both cam covers
brakes bled and refilled
Replaced bent rear right lower control arm
Front air dams and 3 underbody panels replaced
Halogen headlamps replaced
bigislandboxster is offline   Reply With Quote
