The design of the cooling system doesn't really lend itself to easy diagnosis of small leaks. The only sure way to spot a leak is to use a pressure tester or Uview 5000 vaccum kit and it's still a pain to check every connection under the car. In the end, my problem turned out to be my waterpump giving up the ghost. The coolant tank is known to be a source of leaks as well.
2001 Boxster S
6 speed MT
