Old 08-07-2016, 07:37 AM   #1
Ben006
Ben-Auto-Design
Ben006's Avatar
You don't need to remove the axle from the car, and in fact can slide both boots out while removing only one CV joint.
You'll need to lift the car fairly high to make it easier.
Remove the bracings and midpipes, the just unbolt the inner CV joints.
Pop the end cap (hammer and punch), remove the clip on the axle, and the joint should slide out.
If it doesn't, you'll need a puller.
Be careful to use quality boot clamps, or the grease will sling out!
If you don't have access to a lift, you'll have a hard time doing it on the car. If you can take them out, do it.
ASE certified Automotive Master Technician.
Porsche Tech in France.
www.benautodesign.fr
Ben-Auto-Design : Performance parts for 9X6 / 9X7
1982 928 S Euro
Ben006 is offline   Reply With Quote
