Old 08-07-2016, 05:18 AM   #2
Frodo
Where you take it, I can't really say. Dealerships are super expensive...I'd find some independent you can trust.
That said, I'd recommend strongly you drive it little or not at all until you can be sure it's not your water pump going bad on you. That can be a real problem if/when it suddenly goes on you. (There are others that can give you more detailed advice than I can, no doubt.)
Do a search on "water pump." If you want to hear all the possible bad stuff, limit it to posts by Jake Raby.
Last edited by Frodo; 08-07-2016 at 05:49 AM. Reason: Just wanted to add the last line.
