Old 08-06-2016, 12:13 PM   #7
GatorLapis
Jake - Can you elaborate on which unit (part number) expels out the green bits?
Originally Posted by hideehoo View Post
Jake, when you say servo as you referring to the electric solenoid (~$200) or the hydraulic tensioner unit (~$1000) it operates against? Seems like the solenoid is a fairly common failure.
Just pulled my '00S with ~90K out of storage and noticed uneven power delivery in the 3K rev range, some green particles in the oil filter (which is a first), and it just started to throw a 1341 code.
Ordered a Durametric kit to get a little more info before I tear in, but I'm assuming it's either the solenoid and/or actuator going bad. I'll rule out electrical first also, but the particles in the oil filter can't be a coincidence.
Is it this unit? Chain Tensioner 99610505158 - Genuine Porsche - 996-105-051-58 | Pelican Parts
or just this...
https://www.amazon.com/Porsche-Tensioner-Repair-Guides-rebuild/dp/B00AGZVLPW/ref=sr_1_5?ie=UTF8&qid=1470511028&sr=8-5&keywords=chain+tensioner+boxster
GatorLapis is offline   Reply With Quote
