Thread: Audio Experts
Old 08-06-2016, 08:11 AM   #4
dghii
Originally Posted by SilverSSS View Post
you'll get 1/2 the power out of each leg that would otherwise be available out of that leg/channel if it were driving 4 ohms. If you found 2 2ohm speakers and wired them in Series then you would get full/max power out of each leg/channel. Head unit can't drive 2 ohms, amp chips will get hot and go into protect probably, but try enough times, and they will smoke.
Agree, except it sounds like OP is talking small rear speakers, which are not going to be hard to drive, regardless of how they're wired.
I just did this...replaced the 4 rear speakers that had rotted with new aftermarket. Nothing fancy and I wired them like the factory. I'd have to look to see what impedance speakers I bought. 3" speakers are not going to be loud either way!
