you'll get 1/2 the power out of each leg that would otherwise be available out of that leg/channel if it were driving 4 ohms. If you found 2 2ohm speakers and wired them in Series then you would get full/max power out of each leg/channel. Head unit can't drive 2 ohms, amp chips will get hot and go into protect probably, but try enough times, and they will smoke.
