Sux about the work space. So simple preliminary tests would be to hook up a fuel pressure gauge to confirm pump running and fuel pressure, if no rpm indication upon cranking then CPS could be suspect. Gotta ask if you checked fuse to immobilizer?
It's probably the fuel pump....
