Old 08-05-2016, 10:12 AM   #2
911monty
911monty's Avatar
Originally Posted by jaykay View Post
She turns over but will not start. Probably due to my intervention.
After storage, I turn over the engine on the starter to move oil throughout the engine prior to actually running it
After jogging the engine with the starter I pulled the fuse so that she wouldn't start...there was cough so I made sure she didn't run.
Now with fuse in it won't start at all. I have cranked as much I can on one battery charge and motor duty cycle. Each time I believe I can hear the pump running with ignition on.
Any thoughts?
Maybe time to pull the IT trick. Disconnect the battery and boot the computer?
