Old 08-04-2016, 07:38 AM   #2
itsnotanova
Originally Posted by cornontherob View Post
First check the immobilizer for anything strange. Disconnect the battery, move the driver's seat, and take out the immobilizer. Check the fuse on it for signs of damage or being blown out. If that's fine, open the case up and make sure the board doesn't have corrosion or liquid damage on it.
X2
If you do open it up and find moisture. Let it dry out for awhile and pray that it didn't fry anything. Most likely it did though. Then you need to see how moisture got down there.
Woody
