Old 08-04-2016, 02:27 AM   #13
GatorLapis
Your diagrams don't show whats inside the cam adjusters.. or what color it is.
Used valve stem seals are NEVER that color of the new one posted.
This engine has a failing cam adjuster, as evidenced by the debris, and the tell- all code that the engine just experienced.
Thank You Jake. Do you know what part i need to replace as in when I call the dealership or an independent mechanic? Do I just ask them i need to replace my engine's cam adjusters or chain tensioners? Do I need those things below or what part needs replacing?
https://www.amazon.com/Porsche-Tensioner-Repair-Guides-rebuild/dp/B00AGZVLPW
Alex
GatorLapis is offline   Reply With Quote
