Old 08-03-2016, 01:56 PM   #14
madmodz
madmodz's Avatar
Originally Posted by jpc763 View Post
Got the call from the Indy.
AOS - Gone - $240 repair
60K Service + Tubes - $1200
Water Pump has play - recommend replacemnt - $1100
Also...
Tires need replacement $900 and alignment $240.
I am going with the top 3 and taking the tires up with the shop I got them at and enjoyed less than 10K miles on them. Warranty is 15-30k miles so we will see.
It seems reasonable. The water pump was a bit surprising. He said it is a 5 hour job and I will end up with a coolant flush too.
Should I see if he has the Low Temp Thermostat and replace that?
If your going to do the water pump, I would do the thermostat and a drive belt while I'm at it. Belts are pretty cheap. Those are some high prices. I would get 101 things to do to the boxster book and do them yourself.
madmodz is offline   Reply With Quote
