Old 08-03-2016, 02:56 AM   #10
jcslocum
Project Addicted
jcslocum's Avatar
On the Pass side there are at least 4 things than can be leaking:
AOS
AOS to Intake Tube
Oil Filler Tube
AOS Flex Tube
Here is the location of 3 of them
The Top one is the oil filler tube
Middle is the AOS
Bottom the AIS flex tube.
O top of the engine is another flex tube from the AOS to the intake.
The AOS tube to manifold is under the shifter cables.
While you are in there, you should change the AOS and Coolant tank if they are an unknkown.
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
